Harmonic Drive reveals miniature actuator with integrated servo drive
By Editor Design World | March 23, 2021
Harmonic Drive LLC, the leader in high precision motion control announces a new RSF-5 miniature actuator with an integrated servo drive. This evolutionary product eliminates the need for an external drive and greatly simplifies cabling while retaining high-positional accuracy and torsional stiffness in a compact housing.
The RSF Mini and Supermini series is a family of compact actuators that deliver high torque with exceptional accuracy and repeatability. As part of the RSF Supermini family, an integrated servo drive version utilizing CANopen communication is now available. Since it communicates via CANopen, only four conductors are needed: CANH, CANL, +24VDC, 0VDC. A single-turn 14bit (16384 cpr) gear output sensing encoder has been integrated.
Our USA-based engineering team incorporated more features and capabilities into this actuator while maintaining a compact size and low mass.
Key Features:
  • Actuator + Integrated Servo Drive utilizing CANopen communication conforming to DS402 and DS301
  • 24VDC Nominal +7 to 30VDC Supply Voltage Range
  • Single Axis BLDC Motor Controller/Driver with CAN & TTL-UART Interface
  • Field Oriented Control
  • Single Cable with only four conductors needed: CANH, CANL, +24VDC, 0VDC
  • Zero Backlash
  • Pigtail Connectors with two exit options
  • 14bit (16384 cpr) resolution motor encoder
  • Control Modes Including Torque, Velocity, and Position Control, CSP, CSV, CST
  • Harmonic Drive HDL Software for initial tuning, commissioning, and analysis
  • Homing modes include: single-ended, double-ended, double-ended with 16bit autoscale hardstop homing or teachable position
The RSF-5B-IDT Miniature actuator with an integrated servo drive is one of the latest products developed at Harmonic Drive LLC in Massachusetts, USA. The RSF joins the recently released family of FHA-Mini integrated actuators. For more information, visit harmonicdrive.net.
Tagged With: harmonicdrive
Schneider Electric launches Universal Automation Discovery Packs to foster industrial innovation
Encoders from SIKO support Industrial Ethernet
Draw-wire encoders from SIKO measure position, speed and inclination
Incremental encoders configurable via NFC (near-field communication)
