HARTING’s new Han® HMC is the first rectangular connector designed to deliver robust, consistently reliable performance through 10,000 mating cycles or more. Optimized for signal and power, the Han® HMC is ideal first and foremost for applications in the medical sector, laboratories, engineering testing facilities where devices and machines
are often disconnected and reconnected several times a day. For measurement and testing systems, each test step may entail one mating cycle. The Han® HMC also suits modular machine construction and automatic tooling systems, where there is a need for electrical interfaces that can be plugged in and disconnected, over and over again, without incurring significant wear and tear.
HARTING’s Han® HMC connectors are specially enhanced versions of the tried and true Han® industrial connectors, so any device or machine that can use a Han® connector can switch to the same size Han® HMC without modification. The complete Han® HMC series consists of Han® B HMC housings (sizes 10, 16 and 24), inserts with crimp connections, gold-coated crimp contacts with constant spring force, a choice of different docking frames, as well as HanModular® modules that have Han® HMC crimp contacts. All Han® HMC inserts contain high performance grounding contacts. These special properties assure the complete connector’s flawless performance, even beyond 10,000 mating cycles.
Harting
www.harting-usa.com
Filed Under: TECHNOLOGIES + PRODUCTS, Connectors (electrical) • crimp technologies
