Harwin has announced a significant extension to its popular Spring Contact Connector range, with thirteen new models offering design engineers more options to select the best design for each application. The new range includes Extended C and Positive Stop models in eleven different free heights, ranging from 5mm down to ultra-low profile designs a mere 1.23mm above board level.
Miniature Contacts
With these miniature designs, smaller, lighter, low-profile PCB designs can be achieved. Spring Contact interconnects suit a wide variety of applications and markets, including antenna contacts in wearable and mobile applications, RFI screening, LED lamp connections, RFID tags, vision systems, PCB grounding and board-to-board contact.
Positive Force
Spring Contact connectors maintain a positive force against a mating surface, are available in different widths and offer a choice of spring contact forces. Tolerant to significant mating misalignment, 6 of the new designs incorporate a “positive stop” to prevent damage caused by over-compression. The stop also doubles as an anti-hook up feature as a further benefit.
Specifications
All new additions are gold-plated contacts with current rating up to 1.0A. Reliable and durable, Harwin Spring Contacts can withstand up to 10,000 mating cycles. Supplied on tape and reel, the Spring Contact range enables low-cost assembly with automatic pick and place machines.
Harwin
www.harwin.com
The post Harwin extended spring contact connector range now includes 13 types in extended C and Positive Stop styles appeared first on Connector Tips.
Filed Under: Connectors (electrical) • crimp technologies, Connector Tips, MOTION CONTROL
