CHARLOTTE, N.C.– HAWE Hydraulics introduces an expanded product range for the power pack type KA allowing for additional fields of applications for users. The power pack can supply pressure up to 10,000 psi utilizing a radial piston pump or up to 2,900 psi utilizing a gear pump. All KA units are designed for intermittent duty (S2, S3 operation).
The type KA power pack consists of a pump, a tank and a fluid-immersed motor. Some versions feature two pumps and can supply hydraulic consumers with differing pressure levels. The power pack can be positioned either horizontally or vertically and because of its compact design it meets the need for small spatial requirements. There are three tank extensions available, which allow the tank size to be customized from two to ten liters, depending on the fluid demand for the particular application.
The newest option is the auxiliary blower, which significantly reduces the fluid temperature. The auxiliary blower assists the already high-quality thermal dissipation capability of this unit and allows the permissible operation time to stretch even further. This option is available for both vertical and horizontal versions of the unit.
In situations where these power packs are operated under damp ambient conditions, there is an optional silica gel filter available with the vertical power pack, thus preventing condensation. The type KA power pack now extends from industrial applications to mobile applications.
Filed Under: FLUID POWER, Power supplies
Canara Hydraulics – is well equipped with all modern facilities and machineries required in the manufacturing process of Hydraulic Cylinders, Telescopic Cylinders, Power Packs and systems in India.
