HAWE Hydraulics Introduces Type PLVC 8×2
By Patrick Curran | April 29, 2009
CHARLOTTE, N.C. – HAWE Hydraulics has added the new type PLVC 8×2 to its line of programmable logic valve controls. While staying consistent with existing models, this control is equally designed for ample control of complex hydraulic systems. The instantaneous cycle times of the control make it a perfect match for complex regulating and control tasks.
The control links analog, digital and other components with CAN-BUS interface, including: joysticks, potentiometers, stop switches, pressure switches, rotary encoders, speed sensors, valves and many others.
The type PLVC 8×2 has a number of inputs and outputs making it sufficient for even demanding hydraulic systems. It includes 16 proportional outputs, enabling the control of eight functions of the proportional directional spool valve, type PSL, via eight twin solenoids. The basic design also contains six digital frequency inputs, as well as eleven analog inputs, which can be software-switched between 0-5V, 0-10V and 4-20 mA.
The basic unit features a RS232- and a CAN-BUS interface. The programming system supports the CAN protocols CANOpen as well as J1939. The hardware’s core is a processor of the ST10 family that is optimized for mobile applications.
The number of inputs and outputs of the PLVC 8×2 can be doubled with an extension board, which integrates a second CAN-BUS interface. Other options include a clock and memory for data logging, which is used to record measured values or errors.
The control is SIL2-enabled and is applicable for a wide range of mobile applications, including: cranes, crane systems, construction machinery, complex lifting installations, and forestry equipment. It is well suited for placement in tension hydraulic systems such as machine tools and presses.
HAWE Hydraulics
www.hawehydraulics.com
Filed Under: FLUID POWER
