Haydon IDEA™ Drive Stepper Motor Linear Actuator
By Miles Budimir | November 9, 2009
Waterbury, CT – Haydon Kerk Motion Solutions introduces the Haydon IDEA™ Drive stepper motor linear actuator.  The IDEA Drive is an integrated linear actuator, electronic drive, and control unit fully programmable with an easy-to-use patent pending GUI (Graphic User Interface).  Programming the actuator is through the use of on-screen buttons instead of complicated proprietary programming languages.
A unique benefit of the IDEA Drive GUI is the automatic population of the motor and drive parameters based on entering the actuator part number when prompted by the user interface.  Complex parameter calculations or in-depth stepper motor knowledge from the user is completely unnecessary.  For a more experienced user, auto-populated values can easily be adjusted as long as they remain within the safe range calculated by the software.
Another feature of the IDEA Drive GUI is a plotter that visually represents the move profile based on distance, speed, acceleration, and deceleration.  The GUI also provides an interactive “debugger” for easy troubleshooting of the program.  The user can command the drive to execute one program line at a time or multiple lines in a row.
Other features include programmable phase current control (including optional boost current during accel/decel ramping), a single supply voltage of 12 to 42 VDC, and 8 opto-isolated general purpose digital I/O.  The Haydon IDEA Drive linear actuator is available in the captive, non-captive, or external linear versions, both single and double stack lengths.
For more information, visit www.idea-drive.com.
Haydon Kerk Motion Solutions, Inc.
www.haydonkerk.com
Filed Under: Actuators, Drives (stepper) + amplifiers, Motion control • motor controls, Motors • stepper
Comments
  1. Gearsandgeardrivess says
    July 13, 2012 at 2:28 am
    Customized Linear Actuator, Linear Actuator, mini linear actuator, micro linear actuator, Linear Actuator – Manufacturer, Linear, Actuator, Electric Actuator, Linear Actuator, Rotary Actuator, Screw Jacks, Screw, Jacks, Screw Jack, Worm Gear Screw Jack, Worm Gear Screw Jack Manufacturer, Screw Jack Manufacturers, Electro Mechanical Linear Actuators, Bevel Gear Screw Jack, Ball Screw Jack, Screw Rod, Universal, Joint, U Joint, Universal joint, Universal joint manufacturer, Single Universal joint, Double Universal joint and Expandable Universal joints Manufacturers, manufacturers of Universal joint, Reliable
    For more details please visit
    http://www.gearsandgeardrives.com/index.php
Automation 1 Family and iXC4e
49503-ACS Motion-CMxa
SDP-SI-040
