EXAIR’s new HazLoc Cabinet Cooler Systems have been set apart from the competition by achieving the UL classified designation for Div I environments. Thermostatically controlled systems are recommended for the highest efficiency and include UL listed solenoids, also for hazardous environments. EXAIR Cabinet Cooler Systems will install on your purged enclosure in minutes, require little to no maintenance and operate under the toughest of industrial conditions. If you require low cost, ease of use and/or reliability – a HazLoc Cabinet Cooler System will meet your needs.These Cabinet Cooler Systems are engineered and approved for use upon purged electrical enclosures found within classified areas. The areas approved are Class I Div 1, Groups A, B, C and D – Class II Div 1, Groups E, F and G – and Class III. EXAIR’s HazLoc Cabinet Cooler Systems have been tested by UL and meet the stringent UL requirements for these areas. Cabinet Cooler Systems are a low cost and reliable way to cool purged electric control panels found within these environments. They utilize vortex tube technology to produce up to 5,600 Btu/Hr, with no moving parts, which additionally creates a low maintenance solution for cooling your HazLoc purged cabinets.
EXAIR Hazardous Location Cabinet Cooler Systems are available in eight different cooling capacities from 1,000 Btu/Hr. to 5,600 Btu/Hr. This range of cooling allows for choosing the best fit for your cooling needs without placing additional demand upon your air compressor. For more information, visit exair.com. To learn more about EXAIR’s special offer on all Cabinet Coolers, visit exair.com/58/ccpromo.
You may also like:
Filed Under: Cabinets • enclosures • control panels
