    • On the Floor
HBM Launches Version 2.0 of its nCode GlyphXE™ Analysis Software
By Laura Carrabine | March 8, 2010
nCode GlyphXE™ 2.0 helps you to benefit from many improvements for easier and faster data visualization. In addition, irregularities in the measurement data can automatically be corrected using a new software module.
ncode-glyph-xe
The new option of viewing data directly from the browser is a convenient way to work with many data files. The new function is beneficial when a quick look at the measurement data is required, for example, to select the desired data set. Additionally, different measurement data – for example multiple measurements of the same test – can be displayed on top of each other for graphical comparison.
The new module for correction of irregularities allows you to automatically correct negative effects in the measurement signals that might interfere with subsequent analysis. With long-term monitoring, only individual events that may occur only infrequently are relevant. Static conditions between these events expand the data volume and contain only static signal components. In addition, test results may drift due to the effect of temperature variations during long-term monitoring. In the event of a drift in a known measured value, an automatic reset to its origin facilitates monitoring of the test value. A further irregularity results from electromagnetic interference affecting the measurement data in the form of spikes. The new add-on module automatically corrects all these irregularities, such as flat lines, drift and spikes and provides clear display of relevant data.
HBM
www.hbm.com
Filed Under: Software • 3D CAD, Software • FEA, Software • simulation, ENGINEERING SOFTWARE
    • On the Floor
