    • Subscribe!
HD Ultra Slim Multi-Touch Monitor targets industrial uses
By Andrew Zistler | March 8, 2016
hmiAdvantech’s IIoT iAutomation Group is pleased to announce the release of the IDS-3118W, an 18.5” multi-touch open frame touch monitor. The IDW-3118W is specifically designed to meet “end users’ needs” in terms of ID design, operating interface, and installation. The product features a wide viewing area (16:9), a more intuitive operating interface with P-cap touch technology, and simpler installation; making it the best choice for multiple embedded applications such as KIOSK, HMI, etc.
The IDS-3118W supports 16:9 wide screen and HD (1366 x 768) content. The 16:9 aspect ratio provides excellent wide format visual performance. Also, the IDS-3118W comes with an industrial grade panel and LED backlight which saves 20 to 30 percent on power consumption and delivers higher brightness.
The IDS-3118W uses an industrial grade LCD panel with 50,000 hour MTBF. It is equipped with a projective capacitive touch system which has high transmissivity and enables accurate and reliable multi-touch operations. Its extreme durability, up to 50 million touches, guarantees machines are consistently generating revenues and delivering efficient ROI for customers.
The IDS-3118W incorporates simple and slim mechanical design into a two piece metal frame structure. This simple slim design is only 36.15 mm thick while most competing models are above 50 mm thick. The IDS-3118W offers up to 27% more space saving which enables more compact applications. It’s designed with integrated brackets and VESA mounting, which makes for simple integration within any embedded application.
Other features include: 0°C to 55°C operating temperature range, 5-wire resistive and P-cap touchscreen solution, touch interface: USB & RS-232; multiple signal interface with VGA, DVI, and HDMI, integrated bracket for easy installation, and optional value-added solutions: anti-reflective treatment and optical bonding.
Advantech
advantech.com
Filed Under: Automation components, Flanges • supports • mounts • brackets, HMIs • operator interfaces • monitors, Industrial computers
Tagged With: advantech
Bluetooth-enabled digital readout
ADISRA InsightView-IV_main_dash2
ADISRA InsightView delivers advanced equipment analytics
Watlow’s POWERSAFE medium voltage thermal system
Portfolio
Packaging upgrades increase brewery’s efficiency
    • Subscribe!
