HDMI-Compatible Industrial HMI from Maple Systems
By Editor | August 2, 2013
The HMI5000HD Series
The HMI5000HD turns any HDMI-compatible display into a machine interface, and allows for HMI functionality when a keyboard and/or mouse are connected!
The Maple Systems HMI5000HD supports 1280×720 pixel resolution, and is best suited for applications requiring a larger display. Critical processes can be monitored by plant personnel using a wall-mount display easily visible from any location.
The HMI5000HD is light, compact and can be mounted onto a DIN rail, allowing it to share space with your PLC. Ethernet connectiivity and three serial ports support compaibility with a wide variety of PLCs.
Breakthrough Architecture
Breaking through the architecture of HMI, this HMI is freed from a traditional combination of LCD panel and touchscreen. The HMI5000HD can connect to various sized TVs or monitors with HDMI interface. This feature gives more options when selecting a display.
Architecture
Advanced Features
Small, but powerful, the HMI5000HD sports a high-speed 600MHz RISC CPU and enough memory to run resource-intensive projects. It is configured with the EZwarePlus software, making setup quick and easy. You can design and customize your application to meet the exacting needs of your production environment. Combined with EZwarePlus, the HMI5000HD has a robust set of features including alarm management, batch recipes, data logging, enhanced security and much more — giving you the flexibility to make your operator interface a more integral part of your automation control system.
Availability
Maple Systems stands behind your HMI product with a two-year warranty, complementary technical support, an online support center, and numerous online instructional videos.
Maple Systems
www.maplesystems.com
Filed Under: HMIs • operator interfaces • monitors
Tagged With: maplesystems
ADISRA InsightView-IV_main_dash2
ADISRA InsightView delivers advanced equipment analytics
Watlow’s POWERSAFE medium voltage thermal system
Portfolio
Packaging upgrades increase brewery’s efficiency
Passenger,Aircraft,On,Maintenance,Of,Engine,Repair,In,Airport,Hangar
HMI provides assist in aerospace forging equipment
