HD/SD USB Audio/Video Encoder
By Frank Tobe | July 22, 2014
Sensoray announces an addition to their extensive line of high quality, broadcast grade, low-latency and real-time video solutions. Model 2263S is a versatile USB audio/video encoder supporting multiple analog and digital input formats. It captures HD or SD video and simultaneously sends a compressed and an uncompressed (preview) stream to the host. Supported video inputs include DVI, component (with a component to DVI-I adapter, not included) and composite.
SensorayAudio is optionally captured from analog line input, compressed and multiplexed into transport stream. It is well-suited for uncompromising capture of multiple video sources, such as video pipeline inspection, radar and sonar processing, remote video surveillance and traffic monitoring.
Model 2263S is designed as a UVC (USB Video Class) device, which means it does not require a device-specific driver. It is controlled using a video API (DirectShow or Video4Linux). Sensoray provides Software Development Kits (SDK that speed up application development) for several operating systems. A fully functional demo application illustrates the capabilities and serves as a good starting point for Custom Development.
Stream Format
The device implements efficient H.264 video compression. The resulting data is output as an MPEG transport stream (MPEG-TS), or in MP4 or AVI file formats. Audio compression is performed using AAC-LC. High precision hardware timestamps used for multiplexing aid in keeping audio and video data in sync. MJPEG compression is supported for snapshots and AVI streams.
Sensoray
www.sensoray.com
Filed Under: Encoders (rotary) + resolvers, MOTION CONTROL
Tagged With: Sensoray
