Heason Technology’s economically priced motorized positioning stages
By Stacy Combest | August 17, 2012
The range of stepper motor driven miniature positioning stages from Heason Technology are economically priced and suit various low-cost applications in laboratory and research.
The modular and comprehensive range is also ideally suited for medium precision use and includes rotary, linear, goniometer as well as vertical elevation stages along with DSP controlled microstepping drives.
stepper motor driven miniature positioning stages1
Featuring up to 5 microns of positioning accuracy and repeatability of up to +/-0.3 microns, the AX linear positioning stages series offer 15 mm to 70 mm of travel in a selection of precision grades. Its table sizes range from 40 mm x 40 mm to 120 mm x 120 mm. Equipped with a 1.0 mm high precision pitch ballscrew drive, the stages are also fitted with caged ball designs for up to 20 kg loads.
The goniometer and worm gear driven stages including the wedge design elevation stages complement the precision, compact dimensions and dynamics of the linear range. GMT’s motorized stages are all available for complete multi-axis positioning systems, either through low profile adapter plates or by directly mounting to each other.
Although the range is economically priced, the design’s quality is very high, offering veritable attention-to-details features like integral and adjusted card mounted home as well as overtravel switches attached with a neat motor connector system.
Heason Technology completes the range with the DS2 series digital microstepping drives which comes with direction inputs and isolated TTL level step. Available at Heason Technology’s distribution partner GMT Global www.gmtglobalinc.com
Heason Technology
www.heason.com
Linear Motion Tips
Filed Under: Linear Motion Tips, Motors • stepper
Tagged With: heasontechnology
New I/O interface from LINAK expands features, control options
Bosch Rexroth adds high-force model to electromechanical cylinder line
New rail/roller bearing wheel system for high speed, low friction linear motion
Self-lubricating toothed belt axis for clean use in food manufacturing
