NEW BERLIN, WI — J.W. Winco, Inc. now offers series LIXR-VKHT Heat-Resistant Stainless Steel Swivel Casters.
The RoHS-compliant metric casters have swivel brackets of high quality, chromium-nickel plated stainless steel, European Standard 1.4301 (American Standard 304), with a bolt hole fitting. They feature a double ball bearing in the swivel head, a strong central kingpin, a teflon-coated, stainless steel axle tube, and a zinc-plated bolted wheel axle. The wheel is heat-resistant Blickle Hotline® special solid black rubber. Also available is a version with plain bearing.
This smooth-rolling, long-life caster has a load capacity of 100 kg and a temperature range from -30°C to 260°C (-22°F to 500°F), temporarily up to 280°C (535°F). It is particularly suitable for oven racks. A version with heat-resistant grease is available upon request.
J.W. Winco
www.jwwinco.com
Filed Under: Assembly, Fastening + joining • locks • latches • pins
