Heat Sinks Are Designed for Higher Power Densities
By atesmeh | October 7, 2011
Designed for applications requiring high power densities and where forced air cooling is present, Ohmite has released a larger version of its MV/MA heat sink which provides even more heat dissipation. The longer, more efficient fin extrusions on the new version give nearly twice the thermal performance as their smaller MV/MA 102 product. The MV/MA 302 heatsink is 2.2” across by 1.71” tall and uses the same installation mechanism which provides two internal spring clips for mounting up to four TO-247 or TO-264 devices. The convenient spring clips eliminate the need for mounting holes and screws, are resilient and provide the same amount of force after repeated use.
Ohmite Manufacturing Company
866-964-6483, www.ohmite.com
