    • On the Floor
Heavy Duty High Resolution Analog Output Encoders
By Design World Staff | March 12, 2008
Micronor’s ENA361M (hollow shaft) and ESA361M (solid shaft) series ruggedized High Resolution Analog Output Absolute Encoders provide 12-bit resolution with choice of analog output for high reliability industrial automation and process control applications.
These single-turn absolute encoders are offered with choice of 4-20mA or 0-10V output and measuring range options of 45, 90, 180 or 360 degrees. Operate over wide temperature range (-40/+85C) and wide supply voltage (18-30VDC). Optional IP69K protection is ideal for high temperature /high pressure washdown applications in construction and food industry. Standard IP67 or optional IP69K protection.
www.micronor.com
Filed Under: Encoders (rotary) + resolvers, Encoders • absolute, ELECTRONICS • ELECTRICAL
  • Industrial automation accelerates with increased capital spending
    • On the Floor
