Heavy Duty Self-Locking Release Pins
By Patrick Curran | July 17, 2009
NEW BERLIN, WI — J.W. Winco, Inc. announces it now offers series GN 113.6 Heavy Duty Self-Locking Release Pins.
These release pins are RoHS compliant, and use a ball lock mechanism for rapid connection and securing of components or work pieces. A typical example would be bearing shafts which have to be regularly mounted and unmounted. By depressing the spring-loaded push button, the two balls are freed, and by releasing the button, they are locked.
The release pins have nylon plastic handles, with shafts, balls and springs of heavy duty, hardened and highly abrasion-resistant stainless steel, giving them a high load capacity. Series GN 111 split rings with chains are also available to prevent misplacement of the release pins.
J.W. Winco
www.jwwinco.com
Filed Under: Assembly, Fastening + joining • locks • latches • pins
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
