Techno, Inc. Linear Motion Systems introduces the newly improved Heavy-Duty Slide 2, constructed from a single rigid aluminum extrusion profile and capable of handling heavy-cantilevered loads. The 225 mm wide, modular design is available in travels from 122 mm (4.8″) to 2722 mm (107.2″) with a new wraparound motor mounting kit that allows for longer travel with shorter overall lengths. The Heavy-Duty Slide 2 is made to be extremely versatile with T-slots on three sides for easy mounting options.
All models are fit with four precision rails, four bearing blocks, home reference and end limit switches. Customers can choose from inline or side-mounted stepper motors or servomotors. The 16 mm anti-backlash ball screws are available in 2.5 mm (.1″), 5 mm (.2″), 10 mm (.4″), and 20 mm (.8″) leads; and complete CAD Drawings are available on the web.
Techno, Inc.
www.techno-isel.com
Filed Under: Ball screws • lead screws, Linear motion • slides, Motion control • motor controls
