HEIDENHAIN announces the addition of the AMO LMF 9310 multi-section linear encoder to its line of robust linear encoders. This TTL encoder is specifically designed for long length applications (over 10 ft) on manually operated machines and is compatible with HEIDENHAIN’s ACU-RITE brand of digital readouts.
The AMO LMF 9310 is a replacement for the retired ACU-RITE ENC 250 encoder. AMO is owned by HEIDENHAIN so the blend of the product lines exemplifies its commitment to its ongoing Customer First program to best meet customer needs.
The LMF 9310 is an inductive encoder available with measuring lengths from 3,150 mm (124 in.) up to 18,270 mm (719 in.), in 180 mm (7 in.) increments. It comes standard with a 20 µm accuracy grade, 1,000 µm grating pitch, and a 5 µm measuring step.
Encoder features include:
- Contamination resistance – IP67
- Insensitive to interfering magnetic fields
- High precision
- High resolution
- Speed up to 3 m/sec
- Operating temperature -10 °C to 80 °C
- Distance coded reference pulse
- Scanning head includes a flexible mounting coupling to assist in mounting
For more information, visit www.heidenhain.us.
Filed Under: Encoders • linear, Linear Motion Tips
