    • On the Floor
HEIDENHAIN Expands LIDA 400 Scales Series
By Design World Staff | July 2, 2008
SCHAUMBURG, IL ‚–  HEIDENHAIN has expanded its LIDA 400 scales series to include a version that is sure to withstand temperatures that others cannot. This new LIDA 403 scale is now available with glass or glass ceramic (ROBAX‚®, ZERODUR‚®) as its graduation carrier for just this reason as its expansion coefficient makes it especially useful in varying temperatures all the while maintaining high accuracy.
HEIDENHAIN‚’s LIDA 400 series is traditionally based on a steel scale tape with a grating period of
20 ‚µm. This grating period holds true for the LIDA 403. The standard accuracy grade is ‚± 5‚µm with higher accuracies available upon request, covering measuring lengths from 240 to 3040 mm (ROBAX‚® up to maximum of ML 1640 mm).
The scanning head on the LIDA 403 will remain the same as others in the series. There is a reference mark at midpoint (distance-coded now available upon request).
The PRECIMET‚® adhesive film on the rear of the scale will ensure simple mounting.
www.heidenhain.com
Filed Under: TEST & MEASUREMENT
  • Agentic Requirements Engineering: Reduce Friction in Requirements Workflows
  • Five trends in automation for the second half of 2026
    • On the Floor
