HEIDENHAIN’s TNC 640 Control – for Milling and Turning Machines
By Stacy Combest | August 17, 2012
HEIDENHAIN’s TNC 640 control is the first milling-machine control offered with optional turning functions.
With the TNC 640 control, turning operations can now be enabled on a milling machine allowing the operator to transition from Milling to Turning cycles in the same program.  The turning operations can be programmed in plain text, just like the familiar milling operations.  Comprehensive turning cycles are available for frequently repeated operations, such as roughing, finishing recessing and thread cutting.
HEIDENHAIN--TNC-640-1
The TNC 640 is based on HSCI (HEIDENHAIN Serial Controller Interface).  This significantly reduces cabling during setup.  The ergonomic design of the 19” screen, the operating panel with stainless steel fronts and the modern function and status displays provide the TNC 640 with an optimized user-friendly appearance.  The new smartSelect function makes it easier, for example, to select cycles, and syntax color highlighting improves clarity for the editing of machining programs.
The TNC 640 also has a stainless steel control design and a specially prepared keyboard surface and screen frame to eliminate fingerprints.
HEIDENHAIN CORPORATION
www.heidenhain.us
Filed Under: Test + measurement • test equipment
Tagged With: heidenhain
mti
MTI
moog
