    • On the Floor
Heilind Electronics introduces TE Connectivity’s LumaWise Endurance S connector system
By Mary Gannon | July 20, 2020
Heilind Electronics introduces TE Connectivity’s LumaWise Endurance S connector system — an ecosystem of products designed for sensor modules and other control system applications.
Heiland-TE-LUMAWISE-Endurance-S-connectorsThe sensor-ready components of the LumaWise offer all the original Endurance S benefits, along with expanded electrical ratings and alternate key combinations for protected mating. The solution helps to reduce the complexity of street lighting architecture by removing the need for auxiliary modules and associated wiring.
TE’s LumaWise Endurance S is comprised of a standardized Zhaga-certified, sensor-ready interface between the receptacle and module base or ceiling cap. One of the key features of the item is its improved sealing when compared to other systems: The IP66-rated receptacle assembly extends the product life in harsh environments, while the base and dome combinations provide a sealed electrical interface and robust packaging solution.
A simple push-and-twist lock feature allows the product to be installed quickly and easily without the use of special tools and with just one hand. The connectors can be exchanged and upgraded in only a few seconds, without the need to electrically isolate the lighting pole.
The LumaWise features a compact design that is not only UV-resistant, but also visually appealing. The product also offers industry-standard assembly and multiple mounting options for design flexibility.
Best suited for LED light sources and drivers in outdoor luminaires, TE’s LumaWise Endurance S Connector System responds to the need for greater flexibility and connectivity in luminaire design and street lighting architecture.
Heilind Electronics
www.heilind.com
Filed Under: Connector Tips
Tagged With: heiland
    • On the Floor
