Heilind Electronics now stocking HARTING T1 industrial SPE connectors and cordsets
By Mike Santora | January 20, 2022
Heilind-Electronics-product-imageHeilind Electronics, a leading global distributor of electronic components and authorized distributor for HARTING, is now offering the manufacturer’s T1 Single Pair Ethernet connectors and cordset. This series uses Power over Data Line (PoDL) technology to bring the communication, voltage, and amperage needed to power the device. With a single twisted pair of wires instead of the traditional four or eight wires, the T1 Industrial can accomplish communication across common industrial Ethernet protocols.
This connector reduces the number of connections on the device, eliminating the need for an external power supply. Devices that traditionally communicate over Fieldbus protocols are able to join the same IP-based network as other devices – thereby enabling peer-to-peer communication, open-loop feedback, and smart functionality from the main control room to the device.
The T1 Industrial’s mating face is designed to IEC 63171-6 (formerly IEC 61076-3-125) standards and meets IEEE 802.3 requirements for Single Pair Ethernet. The connector is ideal for the construction of future-proof and standardized Single Pair Ethernet communication networks with standardized cabling per ISO/IEC 11801 and TIA 42 specifications.
Heilind Electronics
www.heilind.com
Filed Under: Ethernet — cables • hubs • switches
Tagged With: heilindelectronics
55416_commModule_APL_300dpi_cmyk
Softing introduces a hardware module for implementing Ethernet-APL field devices.
amphenol-pcd-rugged-managed-ethernet-switch-with-icc-logo
Amphenol Pcd rugged military grade managed ethernet switch
Social-Media-750-366
WAGO’s new EtherNet/IP DLR coupler
Ethernet-APL Technology available: standards complete, products entering market
