    • Subscribe!
Heilind Electronics now stocking Molex disposable Thin-Film Battery
By Kelsey Zebrowski | August 17, 2021
Heilind Electronics, a leading global distributor of electronic components and authorized global distributor for Molex, has expanded its selection of electronic component solutions with the company’s disposable thin-film battery.
The thin-film batteries are zinc-carbon primary cells (Zn anode/MnO2 cathode) that nominally deliver either 1.5 or 3.0 volts. Typical applications include single-use or disposable sensing and monitoring devices where lightweight, thin form factor and flexibility are desired.
The vertical construction reduces the footprint compared to other printed batteries and leads to lower internal resistance and improved performance. These thin-film batteries can be applied in a curved surface with a bend radius of 25 mm or greater. The 1.5 V and 3 V batteries support design flexibility and reduce the distance between anode and cathode. They operate at a temperature range of minus 35 degrees Celsius to plus 50 degrees Celsius.
This solution is made with non-hazardous materials and is designed for low-power single-use applications such as wearable electronics, biometric monitoring devices, biosensors, smart labels and environmental sensors. Molex thin-film batteries are found in a variety of industries, including medical, industrial, IoT and consumer.
For more information, visit heilind.com.
You may also like:
  • Heilind Electronics expands Hirose offering with D.FL75 professional video series…
  • Heilind Electronics Partners with Quell Corporation expanding connector portfolio
  • All Sensors ELV Series analog and digital pressure sensors now…
  • Heilind Electronics Partners with Trafag and expands portfolio of pressure…
  • Heilind Electronics expands cable management portfolio with HellermannTyton In-Line Ratchet…
Filed Under: Batteries
Tagged With: heilindelectronics
01_HMS Communication solutions for BESS
HMS presents communication solutions for Battery Energy Storage Systems
Thermally conductive battery adhesive is useful for hybrid vehicles
green cubes
MultiVoltage lithium batteries target material handling equipment
Lithium batteries now shipping from Sager Electronics
    • Subscribe!
