Helical custom couplings
By Mike Santora | August 20, 2019
helical-four-coupling-imageThe versatility of the HELI-CAL Flexure means unprecedented design opportunities for you. We invite you to peruse this sampling of case histories… and then imagine the HELI-CAL Flexure’s application possibilities for your most challenging designs.
Helical Custom Couplings:
Eliminate Axial End Play
Eliminate Backlash and Overtravel
Accommodate Misalignments
Reflect Close-tolerance Precision
Adapt to Low Inertia Requirements
Provide Safe Pre-loaded Springs
HELI-CAL
heli-cal.com
Filed Under: Coupling Tips
Tagged With: helical
Ringfeder — Dynamical torsional stiffness: some couplings need finer tuning
PTDA onProduct Information Exchange
PTDA Transmissions: Lessons from the Pandemic past can shape the future
Shaft collars and couplings feature wide choice of standard bores
