HELUKABEL now supplies pre-assembled data cables for industrial Ethernet systems. With molded M12 and RJ45 industrial connectors, customers can modularly assemble any possible combination of cables and connectors to “design” a product built exactly for their needs. As a system provider of cables, wires and accessories, HELUKABEL is able to offer customers an extensive range of cables to choose from.
In combination with high-speed data cables with transmission rates of up to 10 GBit/s, the molded M12 and RJ45 connectors guarantee a faster and more reliable connection within control cabinets, machinery and in-the-field operations. The cable/connector combinations are directly related to the customer’s intended application use — static, occasional movement, or continuous-flex.
HELUKABEL’s molded M12 connectors come in D- and X-coded versions, both male and female, for use with Category 5 and 6A cables, which cover higher data transmission rates of up to 10 GBit/s. Due to their metal casing, both the connector and socket are extremely robust and are resistant to dirt and moisture when connected, in accordance with IP-67 certification.
The sturdy design of the RJ45 connector makes it particularly suitable for industrial applications. It supports data rates up to 10 GBit/s and has a maximum bandwidth of 500 MHz. The connector is available in a linear or angled version, thus making it suitable for use in industrial areas where space is limited.
Both the molded RJ45 and M12 plug-and-play solutions are UL/CSA approved, making these products suitable for use in machinery and equipment in North America, and anywhere in the world where UL and CSA are recognized.
HELUKABEL
helukabel.com/RJ45M12Overmold
Filed Under: Cables + cable management, Connectors (electrical) • crimp technologies
