Henkel’s new primerless adhesive eliminates the need for a promoter
By Michelle Froese | March 30, 2021
Teroson MS 9222 simplifies your assembly process for more consistent production. Simply apply to clean parts and assemble.
Simplifying the assembly process, Henkel’s new Teroson Primerless MS 9222 eliminates the need for an adhesion promotor — simply apply the adhesive to clean parts and assemble.
The new formula is ideal for a wide variety of work truck applications and manufacturing applications that require high-strength adhesion of loads, thin walls, or small areas.
Teroson MS 9222 is a two-part, fast-cure, silane-modified polymer (SMP) elastic adhesive optimized for painted panel assembly. It delivers excellent adhesion, toughness, and durability. It’s available in 4:1 ratio 400 ml cartridges, as well as pails and drums. Dispense guns and nozzles are also available.
A tough and flexible sealant with good weatherability, the Primerless MS 9222 provides additional benefits, including:
  • Reclaimes labor, time, and floor space dedicated to the current adhesion promotor processes
  • Removes scrap, re-work, and defects related to adhesion promotor errors
  • Eliminates the flammability, health, safety, and VOC (volatile organic compound) issues related to adhesion promoter carrier solvent
Tagged With: henkel
