Designed to suit applications where high reliability, precision, and an optimum weight/power ratio is required; ideally suited for applications with high speeds and power. This coupling is composed of three main items: the two fully turned steel hubs and a single or double disc pack in 304 stainless steel.
Larger and more rigid than “typical” disk couplings
Made in fully turned steel with standard phosphating treatment
Disc pack in stainless steel.
Extremely high torsional rigidity.
Maintenance and wear-free.
Version with double disc pack: GTR/D.
High torque – up to 130,000 Nm (1,150,000 in-lbs)
Maximum Bore Diameter: 205 mm (8-in.)
Available with integrated DBSE spacers to rigidly connect devices over many feet
TYPICAL APPLICATIONS: Servo Motors, Screws, Screw Jacks, Custom Machinery, Packaging Machinery, Fans, Turbo Compressors, Vertical Pumps, Cooling Towers, Printing Machinery, Paper Machines.
Hexelus
www.hexelus.com
Filed Under: Coupling Tips
