High-current DIN Rail Connectors
By Patrick Curran | September 17, 2009
MIDDLETOWN, PA — Phoenix Contact’s new high-current connectors use ring lug/bolt connection technology to ensure a safe and secure termination. HV connectors are available in a wide range of bolt sizes and allow multi-conductor connection.
The connectors feature an integrated spring lock washer that prevents hexagonal nuts from loosening. Both single and double volt versions are available, with bolts ranging in size from 13 mm to 16 mm. The connectors are certified to U.S. standards under CSA International for 1000 V with a range of electrical current ratings from 50 A to 240 A.
Two and three-position connection rails are available for power distribution. Configurable partition plates with feed-through windows allow easy mounting of connection bars. Other accessories include touch-safe covers, rugged end brackets and ZB or UC markers.
The HV series supports switchgear and control applications across a wide variety of industries, including the railroad, power and utility markets.
Phoenix Contact
www.phoenixcontact.com
Filed Under: Factory automation, Connectors (electrical) • crimp technologies, Electronics • electrical
molex-premo-flex
Going small with 3D printing
