    • On the Floor
  • Advertisers
    • PR Submissions
    • Eblast Submissions
High-current Panel Feed-through Terminal Blocks
By Dave Miyares | November 23, 2010
MIDDLETOWN, PA – Phoenix Contact has expanded its offering of high-current, panel feed-through (PFT) terminal blocks. The new PFT series is available in either universal screw (UW) or ring lug/bolt (RW) connection technology.
Phoenix-Contact-PFT_photo
The PFT series provides a secure connection across a wide range of wire gauges. The blocks snap into panel cut-outs without special tooling. Screw and rivet options can accommodate high mechanical stability for conductors.
PFT series terminal blocks are especially useful within the telecom and power distribution sectors. The product range also supports electrical device manufacturers of filters, converters, inverters, transformers, power supplies and industrial batteries.
The PFT terminal blocks are rated up to 600 V UL. Electrical current ratings range from 30 to 112 A.
Phoenix Contact
www.phoenixcontact.com/high-currentPFT
Filed Under: Terminal blocks, ELECTRONICS • ELECTRICAL
  • What DRC Reports Tell You and What They Don’t
  • Big growth in U.S. industrial automation
  • Siemens aims for 80 percent automation in German plant
  • Tech Toolbox: Machine design for food automation
  • Tech Toolbox: Machine design for packaging
    • On the Floor
  • Advertisers
    • PR Submissions
