    • On the Floor
  • Advertisers
    • PR Submissions
    • Eblast Submissions
High Efficiency AC-DC Power Supply
By Design World Staff | July 14, 2008
CARLSBAD, Calif. ‚— Emerson Network Power, a business of Emerson (NYSE: EMR), has launched a high efficiency 100-150 watt ac-dc supply that features both ITE and non-patient contact and non-patient critical medical safety approvals. The new LPS103-M power supply is a compact open-frame design; measuring just 2 x 4 inches, with a height of only 1.29 inches, it has a typical full load efficiency of 88 percent and a power density in excess of 14 watts per cubic inch. The supply is primarily intended for use in information technology equipment (ITE) and light industrial systems, as well as for equipment intended for non-patient contact and non-patient critical use in low power medical, dental and laboratory applications.
The LPS103-M features a universal 85-264 Vac input ‚– enabling it to be used anywhere in the world ‚– and is also capable of operating from a 120-300 Vdc input. The power supply produces a tightly regulated main 12 Vdc output, together with an isolated 12 Vdc fan output; the latter is rated at 1 A, while the main output can deliver up to 8.3 A continuously with convection cooling, or up to 12.5 A continuously with 30 CFM forced air cooling. The main output can be adjusted over the range 10.8 to 13.2 Vdc, and remote sense facilities are provided to compensate for a drop of up to 0.5 V between the output terminals and the load.
Active power factor correction is employed to minimize input harmonic current distortion and ensure compliance with the international EN61000-3-2 standard ‚– the LPS103-M has a power factor of 0.99 typical. The power supply has a maximum safety-ground leakage current of 275 ‚µA, and the main output has a hold-up time of 16 ms minimum when the supply is fed with a 120 Vac input and is delivering 150 watts of output power.
LPS103-M power supplies are comprehensively protected against overvoltage, overtemperature and short-circuit conditions, and feature a ‚‘power fail‚’ signal for remote monitoring purposes which will change state at least 6 ms before the main output loses regulation. The power supplies have a full load ambient operating temperature range of 0 to +50 degrees Celsius without de-rating and can cold-start from temperatures as low as -20 degrees Celsius. Between 50 and 70 degrees Celsius, the output should be derated by 2.5 percent per degree.
Emerson Network Power‚’s LPS103-M ac-dc power supplies comply with the rigorous EN55022-B and FCC part 15 Level B EMC standards for conducted noise and meet all applicable immunity standards, including EN61000-4-2, -3, -4, -5, -6, -8 and -11 levels 3. The power supplies carry a wide set of safety approvals, including UL/TUV/CSA 60950-1 and non-patient contact and non-patient critical 60601-1.
LPS103-M ac-dc power supplies are available for immediate delivery. Standard lead-time is stock to 8 weeks. Pricing starts at US$85 in OEM quantities.
www.powerconversion.com/products/cut/47
Filed Under: Power supplies, ELECTRONICS • ELECTRICAL
  • Siemens aims for 80 percent automation in German plant
  • Humanoids building humanoids, and new robots for agriculture equipment in Kansas
  • Amazon takes on another industry: robotics
    • On the Floor
  • Advertisers
    • PR Submissions
