These PSH series high-efficiency power supplies and PSX series rugged IP67 rated power supplies are part of the RHINO DC power supplies lineup.
RHINO high efficiency PSH series 12, 24 and 48 Vdc power supplies offer best-in-class efficiencies up to 94.5%, temperature performance range of -25°C to 70°C and agency approvals for extreme conditions. The DIN rail clips can be moved to the side of the power supply for side mounting in flat panels.
PSH series supplies are UL 508 and hazardous location listed, UL 60950 recognized, ATEX certified, CE marked and RoHS compliant. High efficiency PSH series power supplies start at $83.00 and have a 5-year warranty.
Rugged RHINO PSX series power supplies are Class I, Div. 2 hazardous location rated with 12 and 24 Vdc output voltages, universal 120/240 Vac input voltage, adjustable dc output, DC-OK LED indication, and output current limitation. Priced from $259.00, PSX supplies are IP67 and NEMA 4X rated, UL 508 listed, UL 60950 recognized, CE marked and RoHS compliant.
AutomationDirect
www.automationdirect.com/dc-power-supplies
Filed Under: Power supplies
