High Efficiency Particulate Water Removal Media from Schroeder
By Design World Staff | May 19, 2009
Leetsdale, PA ‚– Schroeder Industries introduces Excellement ZW High Efficiency Particulate Water Removal Media. The ZW is currently available in 2 styles; 7MZW and 10MZW Spin-ons. Schroeder‚’s Excellement (Z) media excels at capturing dirt particles and is incorporated into the new ZW elements. The Excellement efficiencies, stability, and water holding capacities provided by the layers in the new ZW media means cleaner oil, longer element life, and less downtown.
The layers of the new ZW cartridge element includes n epoxy-coated steel wire fabric, two layers of Z media, water removal media, and spun bounded scrim. The element can be used in Schroeder‚’s MFS/AMS series carts for on-site flushing applications for various hydraulic systems. When used on a kidney loop system installed on power units, the ZW media allows for smaller kidney loop system and lower dimensional clearance and weight. Other applications include mobile filtration systems and bulk transfer systems.
www.schroederindustries.com
Filed Under: Fluid power, Hydraulic equipment + components
Examining direct drive hydraulic maintenance
cylinder
Small, compact cylinder boasts large preload capacity
High modulus plastics for off-highway
Peninsular-Cylinder-top-10-coolest-things
Custom Peninsular Cylinder design named a finalist for “Coolest Thing Made in Michigan”
