    • Subscribe!
High-flex control cables available with 600-volt UL AWM compliance
By Stacy Combest | August 30, 2012
igus® has significantly upgraded two of its top-selling cables designed for flexing applications on automated machinery. Chainflex® CF5 control cables and shielded CF6 cables now comply with 600-volt AWM styles. The new, improved cables are available immediately from stock and at the same price as before.
igus cables
By increasing the operating voltage to 600 volts, CF5 and CF6 control cables can now connect to motors worldwide — particularly in the US, where many motor applications require 480 volts. In addition, the new 600-volt cables can be used in applications where local electrical codes require cables to be the same voltage, regardless of their actual function. For example, if a 600-volt motor-power cable is used, any other cable installed alongside may also need to be insulated for 600 volts — even if it operates at a lower-operating voltage.
The new control cables have an outer PVC jacket that is resistant to oil, according to DIN EN. The conductors are bundled in very short pitch lengths around a highly tensile-resistant rope core and the copper stranding is optimized for dynamic use inside a cable carrier. These design features significantly increase the durability of the cables. Thanks to CF6’s specially designed, braided shield, which has 90 percent coverage, high EMC protection is guaranteed even after millions of cycles.
igus®
www.igus.com
Linear Motion Tips
Filed Under: Linear Motion Tips, Cables + cable management
Tagged With: igus
person's fist holding a handful of igus cables
igus is adding 2,046 new macros to the EPLAN circuit diagram software
igus advances the circular economy with the first e-chain made entirely of recycled material
igus becomes world’s first manufacturer to receive UL approval for halogen-free TPE cables
igus expands E4.1 e-chain modular system for long travels
    • Subscribe!
