The DV Series was designed as the next generation of Clippard’s original EV line of “Mouse” valves. The DV-3 line of Minimatic electronic valves are 3-way control valves, using a patented valving principle. With a solid, sleek design, high flow rates and a cycle life of over a billion, these valves are suitable for many applications across numerous diverse industries. This series is also highly modifiable with many fl ow, mounting, pressure, voltage, material and other options.
• Industry standard for leak-free operation
• Over 1,000,000,000 cycles
• High fl ows in a miniature stainless steel design
• Low heat rise/low power and fast response
• Robust stainless steel “Spider” fl at armature spring
Clippard
Filed Under: Valves, Pneumatic Tips
