Amphenol RF is pleased to announce the expansion of its high frequency SMA connector series with extended frequency cable mount connectors supporting up to 34 GHz. With a lightweight, compact and vibration proof design, they are ideal for a variety of applications including 5G wireless infrastructure, military, RFID and radar systems.
These new cable connectors are available in a straight solder plug configuration and optimized for various conformable and semi-rigid cables. A threaded coupling mechanism ensures uniform contact of the outer conductors which enables the SMA connector to minimize reflections and attenuation at higher frequencies. This allows for a high degree of mechanical strength and durability.
SMA high frequency connectors are machined with brass bodies and beryllium copper contacts, both of which feature a cost-effective gold over high-phosphorous nickel plating ensuring optimal conductivity for the life of the connector. They also incorporate a stainless steel retaining ring and coupling nut, and PTFE insulator supporting temperatures up to 165 degrees Celsius.
In addition to these reliable and durable SMA plugs, Amphenol RF offers a robust portfolio of high frequency connectors.
Amphenol RF
www.amphenolrf.com
Filed Under: Connector Tips
