High Performance 4-Channel PCI/104-Express Frame Grabber
By Editor | November 20, 2012
Sensoray announces an addition to their extensive line of high quality, low-latency embedded video solutions. The Model 911, PCI/104-Express 4-Channel Frame Grabber with Audio Capture, simultaneously captures four channels of analog video and four channels of stereo audio. It captures raw video frames from each channel at up to full frame rate, resulting in an aggregate frame capture rate of up to 120 fps for NTSC and 100 fps for PAL. The high frame capture rate, through two x1 links of PCIe bus interface, makes it well-suited for applications that require uncompromising capturing of multiple video sources in a compact form factor, such as remote video surveillance and traffic monitoring.
A 24-pin header provides convenient access to all I/O signals on the board. The board’s PCI/104-Express connectors support both stack-up and stack-down, and its full conformance to the
PCI/104-Express specification guarantees that it won’t mechanically interfere with adjacent boards.
Sensoray_Model911_PR1
Video and Digital I/Os
The unit supports a wide range of video capture resolutions, including D1, VGA, QVGA, SIF, 4SIF, CIF, QCIF, and 4CIF. Captured frames are formatted as raw RGB or YUV.
Four general-purpose digital I/O signals are provided for controlling cameras and illumination sources, alarm signal monitoring, etc. and can be configured to function as all outputs or all inputs.
Sensoray provides an SDK for the Model 911 that includes drivers, programming examples and comprehensive documentation for both Windows and Linux operating systems.
Sensoray
www.sensoray.com
Tagged With: Sensoray
