High-performance HMI complies with IEC 61131-3 programmable logic controller standard
By Lee Teschler | March 14, 2018
The cMT3090 with built-in CODESYS is a high-performance HMI in compliance with IEC 61131-3 Programmable Logic Controller (PLC) standard. Combining cMT3090+CODESYS with an iR Series I/O Module, the cMT3090+CODESYS integrates the high-performance cMT Series HMI with a CODESYS PLC controller system, which is built upon an innovative architecture where a duo-core CPU runs two independent operating systems.
With a multi-core processor, cMT3090+CODESYS is able to not only provide HMI+CODESYS+IO moduledata visualization with an operable user interface but also runs controller logic. The two systems run independently without mutual interference. The HMI boasts delicate graphical UI and advanced integration features (direct database access, OPC UA, and MQTT). The CODESYS controller system complies with IEC61131-3 and supports multiple languages such as FBD/LD/IL/ST/SFC/CFC.
The cMT3090+CODESYS utilizes a unique internal communication channel to allow the display unit to obtain control information from CODESYS quickly, while at the same time aiding the CODESYS controller system in connecting with other systems like database and third-party controllers. In addition, cMT3090+CODESYS is equipped with dedicated Ethernet and CAN bus interfaces which allow for stable and highly efficient data transmission to satisfy miscellaneous automation demands.
By using couplers that support different bus systems (CANopen or MODBUS TCP/IP), the iR Series I/O module system is compatible with most existing control systems. A patented fixture clip makes it easy to connect many I/O modules and effectively prevents modules from falling off from shock. Flexible module assembly can avoid unnecessary nodes and reduce overall costs. Additionally, iR Series patented iBus technology is strong in noise resistance and efficient in communication that ensures correct and timely update of I/O status.
The cMT3090+CODESYS can be used with CANopen or MODBUS TCP/IP I/O modules from other manufacturers other than iR series I/O modules.
Weintek USA, INC., 6219 NE 181s Street STE 120, Kenmore, WA 98028, (425) 488-1100, www.weintekusa.com
Filed Under: Displays • HMIs • operator interfaces • monitors, MOTION CONTROL
Tagged With: weintekusa
