    • Subscribe!
High Performance ServoWire™ Drives and XD-Indexer Drives from ORMEC
By Miles Budimir | February 24, 2011
ORMEC’s ServoWire Motion & Logic Controllers (SMLC) typically coordinate a network of ServoWire (FireWire) drives for applications where highly coordinated, high performance multi-axis motion is needed. In cases where axes are required that do not need as tightly coordinated motion, the more cost-effective XD-Indexer drive can be integrated into the SMLC system via Modbus TCP communication. The total number of drives on a SMLC controller can be easily expanded well beyond the ServoWire limit of sixteen to more than 100. Overall project costs are reduced with the ability to choose the optimal drive for the performance required on a per axis basis.
ormec_expanded-network
The SMLC Controller features high performance computing capability and offers CoDeSys IEC 61131-3 programming, PLCopen motion function blocks, industrial Ethernet network solutions and FireWire-based drive networking for the most demanding multi-axis motion and I/O control applications.
ServoWire drives from ORMEC are offered in more than 14 models with on board I/O and output currents ranging from 2.5 to 60 amps. Both encoder and resolver feedbacks are available.
The XD-Indexer drives are quickly and easily programmed with table-based software. They provide 32 independent motion profiles synchronizing motion with machine I/O. This drive has fully functional indexing capabilities. The CoDeSys program in the SMLC controller uses a library of function blocks to command the indexing sequences.
ORMEC
www.ormec.com
Filed Under: Drives (servo) + amplifiers, Motion control • motor controls, Networks • connectivity • fieldbuses
Automation 1 Family and iXC4e
49503-ACS Motion-CMxa
SDP-SI-040
    • Subscribe!
