  • Articles
  • Suppliers
  • 3D CAD Models
    • 2019 Winners
    • 2018 Winners
  • Engineering Resources
    • 3D Simulation Resources
    • DIGITAL ISSUES
      • EE World Digital Issues
    • Totally Integrated Automation
High power UV-LED systems for 3D Printing and maskless photolithography
By Leslie Langnau | December 2, 2019
Innovations in Optics, Inc. offers systems that pair high-power UV-LED Illuminators with precision driver/controllers for Digital Light Processing (DLP) applications in 3D printing and maskless photolithography. The UV-LED technology offers reliable and economical advantages over lasers and arc lamps in UV DLP systems. Optical power from these UV-LED systems can exceed 35 Watts of incident flux onto the active area of the DLP.
The Model 3300 series of UV-LED Illuminators comprise a densely packed UV-LED array. The illuminators support the larger of TI’s chipset families, DLP7000, DLP9000, and DLP9500. Standard LED center wavelengths range from 365 nm to 435 nm. Single or multi-wavelength configurations are possible. Up to 18-die integrated into the UV-LED array of the 3300 series illuminators can be driven and modulated independently. Recirculated liquid-cooling allows the UV-LED array to be operated at a very high current density.
Specific models for 3D-Printing in the 3300 series of illuminators feature optical correction of keystone distortion which preserves pixel resolution, reduces stray light and improves image contrast. Models used for maskless photolithography to manufacture printed circuit boards feature multi-wavelength LED arrays to support many photoresists ranging from general purpose dry film to conventional solder mask. A controllable combination of different light wavelengths optimizes the spectral balance of the exposure for all types of UV processed materials.
The 5500 series of digital driver/controllers is specially designed to ensure maximum output and lifetime from Innovations in Optics’ 3300 series UV-LED illuminators. The driver/controllers provide precise, independent, constant current of up to 3A per die to achieve optimal performance. Independent current control to each UV-LED die achieves optimal performance and lifetime by ensuring uniform current density throughout the entire LED array. The 5500 system additionally includes the ability to monitor a temperature sensor that is installed in all illuminators, and a photosensor input for monitoring light output from specific illuminator designs.
Innovations in Optics, Inc. (IOI)
www.innovationsinoptics.com
DESIGN GUIDES
PTC Creo
Leadership in Engineering
September 2019 issue
  • New from Chieftek: Stages, drives, and 2-mm miniature slides for precision automation
  • The Decision-Makers’ Guide to Additive Manufacturing: Explore the essentials of today’s AM environment and improve your results
  • The First 3 Things any Injection Molding Service Checks on Your Parts
  • Elastomeric Couplings Provide Reliable Performance on Pipeline Injector Pumps
  • Consistent linear motion systems with the PBC Linear Uni-Guide
  • New Nested Spirawave® Wave Springs from Smalley
Tweets by @DesignWorld
Copyright © 2019 WTWH Media, LLC. All Rights Reserved. The material on this site may not be reproduced, distributed, transmitted, cached or otherwise used, except with the prior written permission of WTWH Media. Site Map | Privacy Policy | RSS
  • Articles
  • Suppliers
  • 3D CAD Models
    • 2019 Winners
    • 2018 Winners
    • DIGITAL ISSUES
