High Pressure Needle Valves
By Design World Staff | March 2, 2009
ERIE, PA
‚– Innovative Pressure Technologies (IPT) introduces High Pressure Needle Valves. These valves feature a non-rotating stem to prevent galling and scoring, and are engineered to deliver reliable operation at working pressures up to 60,000 psi in temperatures ranging from -100‚° to 450‚°F (-73‚° to 232‚°C). They feature a Vee or Regulating tip stem and six body styles to accommodate a wide variety of applications. Typical applications include general plant service, instrument isolation, hydraulics, pneumatics, pressure measurement devices and venting, among others.
High pressure needle valves feature a gland locking device prevents loosening of the packing gland to minimize leakage potential. They have integral through holes for bracket mounting as standard, with a panel mounting option also available. The end connection is female H/P Cone and Thread. Typical materials of construction are a 316 Stainless Steel body and trim with 17-4 PH stem and glass-filled Teflon packing, with other materials available upon request.
www.inpressure.com
Filed Under: Collars • locking devices, Fluid power, Valves
Next steps in fluid power connections
cylinder
Small, compact cylinder boasts large preload capacity
Clippard Eclipse proportional Valve
Proportional isolation valve offers ultra fine resolution and high repeatability
Fluid power manufacturer receives environmental stewardship recognition
