Pasternack, Irvine, Calif., has launched a new extended series of mmWave, removable, edge launch, PCB connectors that are ideal for SERDES applications like high-speed networking, cloud servers and supercomputing.
This new line of high-speed end launch PCB connectors is comprised of 16 models in four end launch connector interfaces: 1.0 mm (110 GHz), 1.85 mm (67 GHz), 2.92 mm (40 GHz) and 2.4 mm (50 GHz). They provide VSWR as low as 1.10:1 and a wide bandwidth that supports high data rates. These high-performance end launch connectors don’t require soldering and are reusable. Some models offer reduced profiles with a 0.350-in. mounting width, this reduced mounting profile allows engineers and technicians to fit even more launches in the same PCB area. These high-speed end launch connectors feature an outer conductor made of stainless steel and a gold-plated beryllium copper center contact. They are offered in male and female genders.
“This new expanded line of mmWave, removable, end launch, PCB connectors delivers exceptional VSWR performance along with a broad range of frequencies with even more models that are all immediately available with same day shipping,” said Dan Birch, Product Manager.
Pasternack
www.pasternack.com
Filed Under: Connectors (electrical) • crimp technologies
