Intertraco’s one wire braid high temperature hose is used for both mineral and biological hydraulic oils, polyglicol based oils, water-oil emulsions and water. For hydraulic oils, the hose can contain fluids with temperatures from -40° to 275° F (-40° C to 135° C), and occasionally peaks up to 302° F (150° C). For polyglicol based oils, the hose can hold fluids with temperatures up to 185° F (85° C).
The FlexIT HT1 varies in sizes between 1/4 in. and 2 in., and varies in bend radius between 100 to 630 mm. A synthetic rubber tube makes up the inside of the hose, while one high-tensile steel wire braid creates the reinforcement. The hose is covered in a MSHA flame retardant approved blue synthetic rubber.
Intertraco
intertraco.it
The post High temperature hydraulic hose appeared first on Hose Assembly Tips.
Filed Under: Hose Assembly Tips
