    • Subscribe!
High Temperature Resistant Linear Position Sensors
By Patrick Curran | April 29, 2009
Pennsauken, NJ — Macro Sensors has designed a high temperature and mild radiation resistant series of linear position sensors for use in the position measurement of nuclear steam and gas turbine control valves within power generation plants. Constructed of stainless steel, the HSTAR 750 Series Hermetically Sealed Position Sensors can withstand 400º temperature spikes and exposure to radiation at 3×107 Rads for 40 years.
These ¾” (19 mm) diameter AC-operated linear position sensors are being implemented in the rehab of power generation plants to better monitor the position of controls for increased efficiency and reduced operating costs. In a typical power plant, steam turbines can contain a number of control valves – a reheat stop value, an interceptor valve, a governor valve, and a throttle valve. Plant operators must always know the position of governor and throttle valves and the position at start up and shut down of reheat stop and interceptor valves. Typically, theses valves are fully open or fully closed, depending on the turbine start/stop status. As modulating valves, the governor and throttle valves might be 25 or 40 percent open, depending on power generation requirements. Typically, plants have very precise control schemes for valve position to increase operating efficiency and save fuel. As many turbines date back half a century, the HSTAR Position Sensors are being implemented in plant rehabs to provide more reliable position feedback of control valves.
Operating within the harsh environment of a power or steam plant, the HSTAR Position Sensors provide highly accurate position feedback of valve position, providing output to remote electronics that can be monitored by operators. Available in ranges of ±0.050 inch (±1.25 mm) to ±10.0 inches (±250 mm), sensors feature high resolution, excellent repeatability, and low hysteresis as well as the highest sensitivity consistent with good linearity.
Electrical termination of the HSTAR 750 Series is made through a sealed radial connector located near one end. The radial connector results in a through-bore design that permits access to either or both ends of the unit’s core for better mechanical support and core guidance, and easier cleanout in dusty or dirty locations. The radial connector also has a shorter installed length, making the length of the HSTAR 750 Series sensors at least 2” shorter than comparable units with an axially mounted connector for easier installation in tight spaces.
Macro Sensors
www.macrosensors.com
Filed Under: Sensors (temperature), Test + measurement • test equipment
mti
MTI
moog
    • Subscribe!
