Synchronous drive belts and pulleys use teeth to prevent slippage and unwanted speed variations. AutomationDirect SureMotion 5M and 8M (5-mm and 8-mm pitch) high torque synchronous drive/timing belts have a curvilinear HTD (High Torque Drive) tooth profile which allows the belts to have a much larger pulley contact area for improved performance.
The chloroprene belt body is heat and ozone resistant with a high tooth shear resistance. Fiberglass tensile cord provides high dimensional stability and maximum flexibility. The nylon tooth cover provides durability, wear resistance and increased power capacity. Belt operating temperature range is -13/+185 °F (-25/+85 °C).
SureMotion timing belts are suitable for many industrial applications. Belt widths from 9 to 30 mm and circumferences from 180 to 4,400 mm are available. Pitch sizes and widths match SureMotion pulleys to cover a wide range of power transmission requirements.
Priced from $5.50, AutomationDirect SureMotion high torque drive/timing belts conform to ARPM standard IP-27 and have a 1-year warranty.
For more information, visit www.automationdirect.com/timing-belts.
