High-voltage Industrial Ethernet Switches
By Patrick Curran | July 22, 2010
The new 700 Series high-voltage switches are part of N-TRON’s 700 Series, a line of fully managed, feature-rich Industrial Ethernet switches. With up to four fiber ports in an incredibly small form factor, the new series provides the ability to configure fiber rings and fiber uplinks, in an ultra compact solution.
N-TRON-711FX3
Fiber optic communication provides excellent noise immunity for environments where high electromagnetic interference (EMI) is a factor—an ever present consideration in railway and power substation installations. The fiber connection also supports links over extended distances, up to 80 km, essential for wind farms and power utilities. The switches’ ultra compact size and versatile mounting options allow these affordable devices to be used anywhere on the network, even in areas where space is very limited.
N-TRON
www.n-tron.com
Filed Under: Ethernet — cables • hubs • switches, Networks • connectivity • fieldbuses
MTConnect Institute releases Version 2.0 of the MTConnect Standard
OPC UA
Everything is moving – OPC UA Companion Specification “Global Positioning”
Single common conformance test plan to be available for the IEC/IEEE 60802 TSN profile for industrial automation
Ethernet/IP Network specification complete for Ethernet-Apl physical layer for process automation
