Hilti North America, a commercial construction-focused technology, software, and services company, has expanded its concrete anchor portfolio with the launch of Kwik Bolt-TZ2 — a high-performing mechanical anchor that’s easier-to-install and can be used in more application and jobsite conditions than any other expansion anchor currently on the market.
Learn more about the Kwik Bolt-TZ2 in this video.
The innovation is proven to make design easier for engineers and contractors, delivering up to 20% higher tension performance and approvals, while optimizing edge distance and spacing.
“It was a natural progression to take the expansion anchor further to provide an even more optimized fastening solution,” said Rafael Lorenzo Santos, senior director of Fastening & Protection at Hilti North America. “As jobsites become more complex, installing anchors correctly the first time is key to help ensure safety and productivity. With KB-TZ2, Hilti has set a new standard for what an expansion anchor can do.”
Taking the time to ensure a safer anchor design requires a thorough review of the specific applications and load requirements. The use of complex anchors like epoxy or heavy-duty mechanical anchors can be labor-intensive and costly, which can lead to complex anchor redesign requests from project owners or contractors.
The Kwik Bolt TZ-2 has been designed to help make anchoring easier by being the only fractional expansion anchor on the market to offer diamond core hole approvals, a combination drill bit that reduces fatigue on the installer and compatibility with Hilti’s Adaptive Torque module that helps increase installation quality every time.
Additionally, the new KB-TZ2 has improved embedment depths for the thinnest of slabs and an expanded portfolio with 94 different diameter and length options, offering the right size anchor for more applications. This includes the first quarter inch and one-inch diameter, seismic approved expansion anchors.
Modifications to the cone angle and geometry allow the KB-TZ2 to efficiently expand, while the unique sleeve design produces a higher undercut percentage in the concrete. Specialized bolt and nut coatings help prevent over-torquing and provide better pre-tension control to reduce the expansion forces transferred to the base material.
In the end, this enables the KB-TZ2 to deliver unmatched, ultimate tension performance even under seismic conditions.
Features
- Tension: A 20% increase in tension capacities compared to KB-TZ portfolio
- Diamond core approvals: It’s the first wedge anchor on the market with diamond core approvals
- Embedment depths: Increase in embedment depths to provide installation in the thinnest of slabs
- Installation: Integration with the adaptive torque module helps ensure proper pretension
- Portfolio versatility: First 1/4-inch diameter cracked concrete seismic approved anchor, increase in diameters and lengths to better provide the perfect sized anchor for the application
- Edge and spacing: Reduced edge and spacing requirements to provide more design flexibility
Filed Under: Adhesives • epoxies
