The new PMD 200 is an interior layout solution that helps reduce the need for manpower intensive layout tasks.
Hilti North America, a commercial construction-focused technology, software and services company, has launched a suite of new tools, systems, and accessories. The lineup includes new solutions that help contractors further enable advanced anchors, weld removal, and digital transformations — with expanded cordless flexibility on jobsites.
If looking for an anchor to provide a beautiful flush finish for an exposed application, the new KH-EZ C countersunk screw anchors are an ideal solution. Available in 1/4 and 3/8-inch diameters, the KH-EZ C screw anchors offer versatility, durability, and ease of use — fitting a wide variety of applications from handrails to glass shoe attachment.
For those applications where a washer and anchor are typically needed, reach for the Hilti KH-EZ PM and KH-EZ PL pan head screw anchors. These medium (PM) and large (PL) pan head screws help eliminate fumbling with multiple components to anchor during installment, along with providing an oversized washer head to fasten a multitude of fixtures to concrete or grout-filled CMU. With the Torx pattern built into the head design for quick and easy installation, the new KH-EZ C, PM, and PL screw anchors were manufactured with perceptive design to fit into tight spaces effortlessly.
When it comes to stock removal, beveling, weld removal, blending and polishing, Hilti has it covered with the all new Flap Disc, Fiber Disc, and Abrasive Belt portfolio. With productivity and high performance in mind, Hilti’s new tiered portfolio allows you to choose the level of performance based on your needs. Choose between Ultimate SPX for fast material removal, long life and great finish quality; Premium SP for a great balance of speed and durability; or Standard P for convenience in grinding.
These new lines complete Hilti’s recently launched cutting and grinding portfolio, with best-in-class performance. Hilti has a complete metal cutting, grinding and finishing abrasive solutions to get the job done.
Additionally, Hilti has launched enhancements for its diamond core drilling system DD 150-U to make diamond coring even easier. The core motor offers complete versatility to perform a wide variety of coring applications, such as through penetrations and blind holes either handheld or rig mounted.
Hilti’s industrial-performance screw anchors, with corrosion-resistant coating (in mechanically galvanized carbon steel, or hex head).
The new digital display on the tool indicates the ideal amount of pressure required to core efficiently, guidance on what gear should be selected base on core bit diameter as well as a digital level enabling complete control of application and allowing operators to core more efficiently. You can also use the screen to view operation modes and time of tool usage. The tool has offers Bluetooth connectivity.
The PMD 200 is yet another addition to Hilti’s layout tool portfolio, designed specifically for North American interior jobsite layout applications. Powered by Hilti’s 12V batteries, the tool bridges traditional and digital solutions and represents a powerful alternative to the time and labor-intensive methods used for layout today.
PMD 200 was specifically designed to give customers the accuracy and productivity benefits of a digital solution without the added complexity of having to manage AutoCad data or change existing workflows. This new solution is easier to understand and therefore a virtually non-intrusive alternative to traditional jobsite layout methods.
