    • Subscribe!
Hinged Shaft Collar Adjusts, Clamps & Locks By Hand
By Editor | January 15, 2013
Stafford Manufacturing Corp. introduced a lever-actuated, hinged shaft collar for non-rotary applications such as moving gates, sensor heights, stops, and spacers.
The Staff-Lok™ Hinged Shaft Collar is easy to install and simple to adjust and lock in place by just lifting the conformal cam lever, moving it along a shaft, tube, or pipe and then retightening by hand.  Featuring a knurled adjustment screw, this hinged clamping collar never requires tools and is ideally suited for non-rotary applications involving fast, frequent, or temporary relocation.
Staff-lock
Available in 1/2” to 4” I.D. sizes, the Staff-Lok™ Hinged Shaft Collar is machined from steel and has a smooth bore.  It can also be supplied with custom bore designs for joining flanges and with custom features for attaching sensors or other devices.  A one-piece design is also available.  Applications include EOAT, automation, conveyors, and packaging machinery.
www.staffordmfg.com
Filed Under: Collars • locking devices
Tagged With: staffordmanufacturing
Comments
  1. thomas mark anderson says
    July 22, 2017 at 12:40 pm
    how much weight will move it take to move it? 1 inch pipe
What are frictional locking assemblies?
Ringfeder locking assembly in a ball mill for cement production
High-speed couplings from Miki Pulley handle 24,000 RPM with high torque precision
Zero-Max expands Posi-Lok keyless shaft bushing product line
    • Subscribe!
