Muncie Power Products, Inc. has partnered with Hino and Allison Transmission to design the power take-off and installation kit for the Hino 338 Series.
The design uses Muncie Power’s HS24 power take-off with modifications to accommodate the Hino 338 Series. Built with a sculptured housing, the HS24 clears obstructions allowing for easy mounting on Hino chassis.
A smaller overall housing lets the HS24 be mounted on other 10 bolt applications. HS24 installation uses a drop-in shift solenoid and a clutch shift design with torque ratings from 325 ft-lb
Beyond the HS24, the package includes a custom hose kit and wiring harnesses designed to fit Hino 338 chassis with an Allison 3000 Series transmission.
www.munciepower.com
Filed Under: Hose • wraps + sleeves, Hydraulic equipment + components
