HMI with CODESYS 3 PLC and visualization (from Turck)
By Lisa Eitel | November 18, 2016
Turck now offers an HMI with CODESYS 3 PLC — the TX500 HMI PLC. With high-end touch displays and fast processors, these HMIs are ideal for use in small- to medium-size machines whose processes have to be controlled, displayed and operated locally. Each TX500 is equipped with a Profinet master and EtherNet/IP scanner, as well as a Modbus TCP and Mod­bus RTU master. The HMIs can also be run as field devices for both Modbus protocols. More after the jup.
hmi-with-codesys-3-plc-and-visualization-from-turck
CODESYS 3 allows the lean and simple programming of the PLC and visualization functions. The latest processor technology of the units guarantees the smooth handling of computing intensive processes such as moving image visualizations. The high resolution TFT display with 64,000 colors enables attractive and high performance display of graphics and animations. The front panel of the TX500 series is protected to IP66.
Two RJ45 Ethernet ports, a serial interface for RS232 or RS485 as well as two USB ports are provided on the terminal side. An additional SD card slot makes it possible to expand the 128 MB internal data memory. Turck is offering the TX500 series in three variants with different display sizes and resolutions — two 16:9 displays with 7” or 13” (TX507 and TX513) diagonals and one 10” device in 4:3 format (TX510). The two smaller displays offer 800 x 400 pixels, while the large TX513 comes with 1280 x 800 pixels.
Turck is a pioneer in industrial automation technology, providing customers with a comprehensive line of quality and advanced technology products in a fast, flexible and accurate manner. With more than 4,000 people working in 28 countries, Turck has built global partnerships with customers based on engineering expertise, flexibility and our willingness to take on engineering challenges that others won’t. For more information, visit www.turck.com.
Motion Control Tips
Tagged With: TURCK
Lisa Eitel
